Please i want the bolts torque specs for McLeod Clutch ASAP necessary
Old 03-18-2011, 09:32 AM
PONTIAC SLP's Avatar
Default Please i want the bolts torque specs for McLeod Clutch ASAP necessary
Hi , Like it says , Will install McLeod Street Twin Clutch steel flywheel into my fbody
* I want the bolts torque specs for
*Clutch
*Flywheel
Old 03-18-2011, 03:28 PM
studderin's Avatar
check there site, you can DL the install file for the clutch you have.
Old 03-19-2011, 06:48 PM
Billy M's Avatar
*Clutch
*Flywheel
65ft lbs on the crank.
25ft lbs on the floater.
35ft lbs on the pressure plate.
Old 03-19-2011, 06:57 PM
Thanks dude , But what's floater ? Its the flywheel ?
Old 03-19-2011, 07:13 PM
85MikeTPI's Avatar
Thanks dude , Buy what's floater ? Its the flywheel ?
The floater is the steel plate between the twin discs.
Quick Reply: Please i want the bolts torque specs for McLeod Clutch ASAP necessary
