re-use clutch?
Old Feb 17, 2004 | 03:54 PM
Greg Fell's Avatar
Question re-use clutch?
I'm considering putting my spec stage 3 carbon from my 00 t/a in my 01 zo6. I have a fidenza flywheel I'm going to use, and will probably change to the 3i disc/x pad, but am wondering if I can turn or re-use the pressure plate? There is some wear on it, from a couple 3-4 trips to track on slicks and the bottle.
Any thoughts?
Old Feb 20, 2004 | 12:58 AM
jmd's Avatar
jmd
If the pressure plate was worn-in with the disc, you don't need to resurface it. Run the PP & disc w/ the new flywheel, and put some miles on it, and everything will be cool. BTDT.
Old Feb 20, 2004 | 08:43 AM
Greg Fell's Avatar
I'm wanting to run a new disc, a 3i. Can I still use the pressure plate with this?
Old Feb 25, 2004 | 01:39 PM
Greg Fell's Avatar
Anyone?
