What bellhousing is this??
Old Feb 18, 2004 | 08:47 PM
redmist's Avatar
Default What bellhousing is this??
Specifically what slave cylinder, clutch fork, throwout bearing setup is this LS1 T56 bellhousing made for?? Thanks
http://e21.tricord.cjb.net/members/redmist/trans.gif
Old Feb 20, 2004 | 12:29 AM
jmd's Avatar
jmd
You narrowed things down quite well.
The only LS1 vehicles with a T56 are the F and the Y. Only the F has a transmission (as opposed to a transaxle.)
Which makes it a 98-02 f-body bellhousing and those were only setup with a hydraulic throwout bearing. There is no fork. The slave cylinder bolts on.
Old Feb 20, 2004 | 07:26 AM
Gimp98TNT's Avatar
That dosn't look like my stock T56-LS1 bellhousing. Mine dosn't Have those two holes in the side of it.
Got any other pics?
Old Feb 23, 2004 | 08:09 AM
kossuth's Avatar
Got any other pics?
Huh??? That's a LS1 bellhousing. Those holes are where the bleeder and the slave cylinder line goes on the driver's side of the unit.
Old Feb 23, 2004 | 08:20 AM
Fireball's Avatar
Wink
Got any other pics?
yes it does. you can't see the upper hole when installed in the car (its where the bleeder is) and the lower hole is where the line coming from the master cylinder connects to the slave
