M6 gears sometimes lock out?
Just installed a stage 2 diamond clutch kit new slave and master thinking this would fix the problem but no. Just the same as when shift skip locks you out of second gear I sometimes have the same problem with fourth gear and reverse is just hard as hell to get into to. Reverse I'll just have to keep applying pressure and it'll go into gear. As for fourth I have to double clutch and then it'll go in. Only those gears have the problems...any ideas?
