cruise control help
Old Apr 4, 2011 | 01:06 PM
dodson55's Avatar
Default cruise control help
i just did a t56 swap in a 01 camaro everything is working fine except for my cruise does not work anymore does anyone know what i need to rewire to get this to work again
Old Apr 4, 2011 | 11:53 PM
cpo's Avatar
cpo
I think you will need to install cut-off switch for the clutch pedal.
Old Apr 5, 2011 | 08:11 AM
garys 68's Avatar
Did you go from auto to manual?
If so, did you have your ecu tuned for manual, including your vss signal?
Old Apr 5, 2011 | 09:12 AM
cpo's Avatar
cpo
No, mine is a factory manual. But I know there is a CC switch for the clutch.
Old Apr 5, 2011 | 10:44 AM
garys 68's Avatar
If the ecu was retuned for a T56, it will be looking for a clutch pedal position swith rather than the torque converter unlock/brake switch on automatic cars.
Old Apr 5, 2011 | 07:33 PM
dodson55's Avatar
it has been tuned for the 6 speed and how do i need to wire the clutch position switch
Old Apr 6, 2011 | 07:03 AM
garys 68's Avatar
Search the conversion forum for the pinout and wiring diagram for your year.
Be sure to use the F body. Turns out the truck and corvette (DBW) applies 12 V, while the F body grounds with the clutch pedal switch.
Old Apr 7, 2011 | 12:16 PM
dodson55's Avatar
thanks for the help i think i found my problem
