lq4 flywheel fitment problems
Old 05-04-2011 | 11:54 PM
lq4gp's Avatar
Default lq4 flywheel fitment problems
i have a 2004 lq4 out of a gmc yukon that i am putting into a 1987 grand prix. I am running a 4 speed as that is what my budget will allow. My problem is i bought a flywheel for a 1999 camaro thinking that they were pretty much all the same but when i installed the flywheel i noticed that the starter teeth were engaged with the ring gear already. Is there a starter out there with a shorter nose on it? or is there a flywheel out there with the ring gear on the clutch side of the flywheel? any help would be appreciated.
Old 05-05-2011 | 09:50 PM
jmd's Avatar
jmd
I don't know, but I'd check the starter pinion gear to see if it can be pushed back in the starter (starter is bad) or compare / test fit a Camaro starter.
Old 05-05-2011 | 10:24 PM
lq4gp's Avatar
Ya im sure the starter is fine ive checked that.... Im getting ahold of a truck flywheel too to see if they are any different from the camaro flywheel.
