6.0 finally back but...
OK my initial 6.0 went down due to p 2 v clearance issues. So the motor was torn down and rebuilt.
I added a mcleod twin disc. new slave cyl.
Heres whats happening.
When the car is still and idling (still tuning) a little 500rpm surge sometimes happens. When it happens I can feel the BRAKE pedal softly going up and down with the engine rpms I can also somewhat feel it in the clutch pedal but not as much.
I dont have the pressure I use to have. but the pedal is all the way up. Its a mcleod adjustable.
Also since the swap I cant get into first or reverse unless the car is off. The only changes was the clutch. Probably two totally different issues. Any ideas
Of the two cars in the sig this is the Z28
