How do you bench bleed?
Old May 12, 2011 | 05:19 PM
airattack111's Avatar
Default How do you bench bleed?
I got a new master cylinder and would like to bench bleed it before I install it, are there any good write-ups out there on how to do this correctly?
thanks
Old May 12, 2011 | 10:09 PM
Ryans99ls1's Avatar
I somewhat "bench bled" mine once i installed it. I made sure the resevoir was full and before i connected it to the slave cylinder and had a buddy push the pedal(not all the way down) while i popped open the end of the line. just dont hold the line open or youll be letting air back in . then went about bleeding it normally through the slave.
Old May 12, 2011 | 11:31 PM
jmd's Avatar
jmd
You can bench bleed it while it's installed:
https://ls1tech.com/forums/13837919-post3.html
Old Jun 9, 2011 | 01:27 PM
Cosmos's Avatar
I suppose you could use the remote speed bleeder with this as well. Just route the speed bleeder end into the fluid res and you should be good. Am I correct?
Old Jun 9, 2011 | 02:37 PM
jmd's Avatar
jmd
- Yes.
