Flywheel retention tool
I went looking for it to pepboys, kragen, autozone, sears, snapon.com, and napa. They don't have it in any of these places.
Where did you do-it-yourself guys get it? I'm out of ideas.
It is necessary right?
The only time you need a flywheel holder is if you're trying to remove/install the harmonic balancer bolt on an A4 or if the motor is on an engine stand.
Mike
Mike
Also, if you're by yourself, stick a TQ wrench on the crank bolt and hold it with your legs while you break the Flywheel bolts loose. Shadetree type ****
all you have to do to get those flywheel bolts off is take a large Flat blade Screwdriver and stick in in one of the teeth on the fly wheel and the starter housing.
They aren't that hard to get off.
I have done a dozen of them like this and have yet to damage anything.
Tom
