First time replacing a clutch, need a few pointers.
What I'd like some help with: How much of a pain in the *** is this going to be? Will the exhaust manifolds get in the way much. Will I have to pop them loose to get the transmission out. Is there a way to disconnect the shifter from the transmission itself? I only ask because I have an aftermarket Hurst shifter and one of the bolt heads is stripped out and going to be a real pain to drill out if I have to. I was also wondering if now would be the time to go ahead and do the exhaust while I'm at it.
Any help, tips, suggestions on anything else I should take care of while I'm at it will be greatly appreciated.
THis isnt the same clutch but it should answer most of your questions. I just googled this quick.
http://www.installuniversity.com/ins...ch_install.htm
Stock, there's an exhaust hanger attached but easy to deal with.
Use the alignment tool for the clutch disc while/before you tighten pressure plate bolts. Wobble it up and down; hold it about 5/8 of the way up, tighten bolts.
Also, if you don't have a trans jack, make sure you have someone else under there with you to help you lower it to the ground (and get it back up more importantly). I made a wooden platform for a regular floor jack and it worked well coming out, but going back in it rolled a little and i tried to catch it and i ended up snapped the line off the slave cylinder. $100 a two days later, I used the same platform, but with a second set of hands to hold it steady.
Its not an awful job. That install guide is pretty good. Its no where near as heavy as an A4, so that's nice. Just torque to spec and do everything slowly and you'll be really pleased.
Another tip I have is be PATIENT. Your only gonna **** **** up and waste more money if your not.
I hope your kidding, that slave spring is so easy to compress, go ahead and pull the threads out of your bell housing, I don't care it's not mine. If you can get it all the way in great, and I would never recommend trying this right off the bat, but I fail to see the danger in it if it takes next to no effort and you alternate sides going slowly and patiently. If it's stuck on something serious and it's taking any notable effort obviously you don't use the threads to pull it in. I just had no angle that worked to push/pull/pry the tranny in there and the bolts threaded in like butter.
It worked when nothing else did, and I didn't break/damage anything
good luck I just put mine back in last week so its pretty fresh in my head PM me if you have any questions
[/QUOTE]
Please don't work under your car with it on cinder blocks.
Don't forget to drain the fluid before you pull the drive shaft or have a pan ready as the fluid will pour out the tail shaft.
