Bolts for bell housing, clutch, etc
I need bolts to mount the bell housing to the engine(lq9), mount the flywheel and clutch cover. The dealer doesn't sell them....or at least thats what they said on Friday. Any one know a supplier and the part numbers?
You can buy the Bellhousing ---> engine bolts at any good hardware store. They are just a flanged bolt. M10 x 1.5 x 40mm
the flywheel---> crank bolts might be harder to find. I have a set from a stock engine (re-usable) that I would sell you if you can't find any others. For the Pressure plate ---> flywheel, I would recommend some ARP bolts, as they're only like $20, but stock ones will suffice. Be sure to follow manufacturer's spec when installing.
PM me if you need said bolts.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
I would not be doing any more business with that parts department.
go here for diagrams with GM part numbers: http://www.compnine.com/
