McLeod Scattershield
Old Jun 24, 2011 | 09:05 AM
Jekyllandhyde's Avatar
Default McLeod Scattershield
I'm putting together parts for the T56 swap into a 91 GTA. I bought an LT1 T56 transmission and it comes with the bellhousing, but I like the idea of putting a scattershield in there. I was looking at the McLeod 8760-00 bellhousing. For the people who have this, does it come with the bellhousing bolts? if not, can I re-use the stock ones or does somebody know of an ARP part number for them? Thanks!
Old Jun 24, 2011 | 02:56 PM
xXxSilveradoxXx's Avatar
I've got a McLeod Scattershield for my 02 WS.6. I purchased it years ago so I don't remember the exact part number but mine did come with all the necessary bolts.
Old Jun 24, 2011 | 03:18 PM
calhoon's Avatar
If it is an SFI approved bell, it needs class 8 or better bolts. the orig bolts won't meet that. I suspect a bolt set will come with the bell. Also, it sould have an engine plate.
Old Jun 24, 2011 | 03:27 PM
Originally Posted by calhoon
...Also, it sould have an engine plate.
Yes, it does.
Old Jun 24, 2011 | 03:30 PM
Jeremy@RPMTransmissions's Avatar
I have used both and I liked the Quicktime bellhousing a lot better. It comes with the bell to block mounting hardware.
Old Jun 24, 2011 | 03:40 PM
BrianSF-GA's Avatar
If (but probably when) I do a clutch upgrade and T56 build, I also want to go back with a scattershield. Are both the McLeod's and Quicktime's direct bolt-in for an SS/LS2 or do they require modification?
Old Jun 24, 2011 | 03:57 PM
They should both bolt-in. The LS1/2 block is nearly identical on the back side.
Old Jun 24, 2011 | 06:13 PM
BrianSF-GA's Avatar
.... thanks.
Old Jun 24, 2011 | 09:05 PM
BADD SS's Avatar
THIS^
fits like a glove. Ive done 3 now, and never a problem..... Not always the case with the mcleod, IE: break out the grinder and a snickers, you're gonna be a while.
Old Jun 24, 2011 | 11:03 PM
BrianSF-GA's Avatar
Originally Posted by BADD SS
THIS^
Good to know...I never like having to break out the grinder.
Old Jun 28, 2011 | 08:58 PM
WS6 SRT-8's Avatar
I don't have any experience with the McLeod. But my Quicktime went back in like the stock one. Fit perfectly.
Old Jun 28, 2011 | 09:11 PM
Smo's04Gto's Avatar
Quicktime also fit great,be sure to get a remote bleeder.
Old Jun 28, 2011 | 09:27 PM
boss79z's Avatar
I have the Mcleod (had to cut), and my buddy has the Quicktime (didnt have to cut). Both came with the necessary pieces and both are well built.
Old Jul 4, 2011 | 06:48 PM
Thanks for the answers folks, now for the final question, does it need offset dowels to align it with the transmission or do you simply bolt it in like the stock bellhousing and go?
Old Jul 4, 2011 | 11:25 PM
boss79z's Avatar
Mcleod bolted in like the stock bellhousing and so did the quicktime.
