B&M shirt stick?
I have a b&m shifter on my car (came with the car when I purchased it), and the b&m's I see on here have a longer stick than mine. Mine says (short stick) on it. Did they make b&m's like this or do I have some other shifter? After reeding the b&m shifter reviews here mine seems exactly the same, just shorter.
any ideas?
any ideas?
You probably have the older model b&m ripper where you could change out the handle and someone has put a Lou's short stick on yours. The newer b&m rippers are a solid handle so you can't change it out.
