Spec 3 Installed
Old Feb 29, 2004 | 10:52 AM
00Streak's Avatar
Default Spec 3 Installed
I installed my clutch this weekend with the help of a friend. He happens to work at a Volvo dealer so I got to use the lift, air tools, tranny jack. Its a fairly cut n dry job that just takes a little time. Bleeding the hydro's were fun, as brake fluid burns like hell in cuts. But hell the presurized bleeder they had made even that a little easier. Break in has begun and so far there is a bit of chatter if i dont rev it higher on take off. But i can definately tell its good n grabby.
Old Feb 29, 2004 | 01:56 PM
KALEL's Avatar
that is good to hear....im going to put mine in as soon as i get my tranny jack....im not going to try to take that SOB out w/o it
Old Feb 29, 2004 | 04:12 PM
00Streak's Avatar
yeah, a tranny jack is a good thing. that little sucker is a little heavy.
S
Old Feb 29, 2004 | 05:58 PM
Josh2021's Avatar
Good to hear you got your clutch in. I got mine installed yesterday aswell. It took alot longer than expected. It seems that every time I work on my car nothing goes as it should and that if it can go wrong it will. I love my Spec III and I haven't had any problems with chatter.
Old Mar 1, 2004 | 08:40 AM
00Streak's Avatar
Im the same way. it always takes longer than most. one reason mine took so long was that i left the hydraulics at home and didnt realize it untill the tranny was sitting on the ground. had to burn an hour borrowing a buddys car and driving home to get it.
chatter isnt bad at all in mine, only because i forget its not stock and dont give it enough rpm. When i raise it to like 2200 and go, i dont hear a thing other than the exhaust.
S
Old Mar 1, 2004 | 03:35 PM
Josh2021's Avatar
Yeah, I had to burn up some time aswell to go get my master cylinder that I left at my apt. Can't wait until I can actually hammer on it.
Old Mar 1, 2004 | 04:09 PM
00Streak's Avatar
HAHA yeah im still on break in as well. im just dieing to do a 5k dump
S
Old Mar 2, 2004 | 02:32 AM
pdd's Avatar
pdd
S
ME TOO
