corvette triple cone syncronizers
Old Jul 29, 2011 | 12:19 AM
oldmano2z's Avatar
Default corvette triple cone syncronizers
explain this please, all tests with my new shifter and my tick master and clutch indicate 1/2 syncros gone. i previously installed carbon fiber rings,and billet keys. will triple cones be possible in t56? for 1/2 and 3/4 syncros? will i still be able to use billet keys? i've got a teardown manual i need to verse myself but i've had some good help understanding the workings.
Old Jul 29, 2011 | 01:15 AM
jmd's Avatar
jmd
It's possible to build a triple 1-2, double 3-4 and single 5-6 box if that's what you're asking.
Are you starting w/ an 02 Z28 or Z06 by chance?
Billet keys can be used, yes.
You might want to go into what tests you have done.
Old Jul 31, 2011 | 07:43 AM
oldmano2z's Avatar
i'm not understanding matthew seems that you can go in depth into these trans . might you be able to explain this to this old man ? i gotta crawl under to pull trans , so i might see about the mod. just kinda bummed out i did all this work and gotta take it apart to fix it after only 3k on ls6/a4 to 6speed changeover on my 02 z
Old Jul 31, 2011 | 12:45 PM
jmd's Avatar
jmd
02 Z28 or Z06?
For simplicity's sake:
The 02 Z28 has double friction surface 1st/2nd and single friction 3/4, 5/6 and Rev.
The 04 GTO has triple friction surface 1st/2nd and double friction 3/4, 5/6 and single fric. Rev.
The input shaft, all forward gears & synchros and the mainshaft are different to change an 02 Z28 to a triple/double style trans. In short, locating a GTO box, swapping the offset shift lever and putting it in an 02 Z28 and selling the original is the most cost effective. But, that changes you to the M12 gear ratios which you may or may not want.
An MM6 gear ratio F-body/GTO style triple/double box was not produced so it's a custom build.
Old Jul 31, 2011 | 08:40 PM
oldmano2z's Avatar
thank you sir for your explaination it . i understand now guess i'll stay with what i have t-56 . i just wonder why the 1/2 snycros went . it will have to wait till i pull it out. thanks again for your help.... old man
By Brett Foote | 2026-06-04 05:00:17
