a4 to m6 wireing
From the external harness you are just extending the length of the VSS plug. Other than that you can do the reverse lockout by either running it to the PCM or a lot simpler to run one wire to the blue wire on your brake pedal switch and the other wire to a ground. I used the plate that the air bag sensor sat on as something else was grounded there anyway.
hate to tell you to read or do a search but it will really help you. i, and many others have compiled information for the swap here::
https://ls1tech.com/forums/manual-tr...uested-30.html
know its alot to read but it will be well worth it. hope this helps
purple/white and dark green for the clutch but how does it connect to the back of the clutch?
light green and brown into a pig tail then where does that go? Plugs into the tranny?? Im lost? What about the reverse lockout? These instructions are whack and doesn't explain how to do it if anyone can help pm me please
To break it down a bit:
The orange/black and black wires just get connected together. Cut them, use a simple j-hook splice, solder, and wrap.
The purple/white and dark green wires need to be extended long enough to reach your clutch pedal. On the clutch pedal there is a black switch. It was a square looking thing that had a button on it that gets pressed in when the clutch is pushed down. You can get simple electrical connectors from pretty much anywhere that sells hobby electrical tools (Wal-Mart is where I got mine, any auto store will have them too), attach them to the ends of the wires you extended and plug one in the top and the other in the bottom.
The light green and brown get connected to the pigtail for your reverse lights. This is plugged into a pigtail on the passenger side about near the center of the transmission. You will need to use some auto wire to elongate this so it'll reach, then splice, solder, and wrap.
The VSS wires need to be elongated enough to go over the transmission from from the passenger side on the exterior harness and get plugged into the downward facing plug underneath the reverse lockout solenoid.
There are two ways to wire in the reverse lockout. One requires you to locate the unused pin on your PCM and use that. The other has you ground one wire off the pigtail to the chassis and run another wire to the light blue wire on your brake pedal switch. This is what I did. This makes it so you must depress the brake pedal to go into reverse. WARNING: Be very careful when braking in sixth gear then trying to go into 5th with your foot on the brake. You can seriously destroy your engine, tranny, and a lot of other things.
