Flywheel Balanced?
Old Mar 2, 2004 | 08:21 PM
sununix69's Avatar
Default Flywheel Balanced?
How can you tell if your flywheel is out of balance?
Old Mar 3, 2004 | 05:53 AM
Stick only's Avatar
The factory clutch and flywheel are balanced as an assembly. If you install another clutch assembly that is zero balanced, like our aftermarket units, the flywheel should be spun balanced to zero to insure no vibrations.
