clutch install;pic of slave cylinders and shim
Just wanna make sure everything is fine before putting the tranny back. The old slave was different; my searches showed that the new unit is different. The round green disk is the old shim, i think..So with Monster clutches they say there is no need to shim at all.. Is that ok to put the slave just like this?
UNDER PRESSURE MOD
The clutch disc should not move at all when the pressure plate is bolted down. That's how it works. The pressure plate is now squeezing the clutch disc against the flywheel and the clutch disc matrial is the glue that holds them together via friction. Then when you push in the clutch pedal, the slave cylinder moves towards the flywheel, pushing down on the fingers of the pressure plate diaphram, moving the pressure plate disc away from the clutch disc, disengaging the clutch disc and allowing it to spin independantly of the flywheel/pressure plate.
