2002 Trans Am hard to shift @ high RPMs
I have an 02 Trans Am with an LS1 and 6-Speed. It drives very well in town, but is very difficult, almost impossible, to shift at high RPM's. Can anyone help? I have no idea what's going on.
You should read through the manual transmission section. It answers all of these questions.
But there are usually 2 issues that can cause this...
1. Fluid needs to be changed (look to see if its a dark color), look up 'mighty vac'
2. You need to do the 'drill mod', or step up to a tick master.
Best of luck!
Best of luck!
LS1TECH Sponsor
Very common problem that has been fixed for thousands of people by our Adjustable Master Cylinder kit: http://www.tickperformance.com/tick-...or-ls1-f-body/
Someone brought this issue up to me. I am about to drop some serious dough on the car. and one of the purchases is a new clutch, which i thought would get rid of this problem since I am replacing the slave cylinder. Can someone elaborate first what causes this hard shift problem. I have the same issues. And second, how does this adjustable clutch master cylinder alleviate the problem?
LS1TECH Sponsor
Our Adjustable Master: http://www.tickperformance.com/tick-...or-ls1-f-body/
Our Tick/Monster Complete Clutch Swap Package (if you want to upgrade the clutch at the same time): http://www.tickperformance.com/ls1-f...-swap-package/
