pro 5.0?????
Old Aug 11, 2011 | 05:30 PM
white/blue99ta's Avatar
Default pro 5.0?????
i have the pro 5.0 and after i just swapped the clutch out...i went to put the two springs back in the base of the shifter but they were curved and warped?? how that happened i have no idea..ive looked everywhere to find a replacement springs but no luck? Called pro 5.0 and they dont sell the parts, i gota buy a whole new setup...wth!! does anyone know a good place to find these springs or am i gonna have to buy a new shifter??
Old Aug 11, 2011 | 05:58 PM
Blwn_by_Twins's Avatar
Why did you take the shifter apart?
Old Aug 11, 2011 | 06:01 PM
cause i had it up on pretty crappy jackstands so i couldnt get the car high enough...the top plate wouldnt clear the hole in the floorboard so i took out the four bolts and took out the shifter from the base.
Old Aug 11, 2011 | 06:09 PM
therealcreeper's Avatar
I'm sure you can find something from mcmaster that will work, you can buy pretty much any length/width/strength you can think of
or I'll give you a few bucks for it you can put towards a new shifter and I'll give it a shot rebuilding it
Old Aug 11, 2011 | 07:47 PM
f*** it.....im gonna go w either b&m or hurst.....pm me if you want this 5.0
Old Aug 11, 2011 | 08:34 PM
But why did you disassemble the shifter is what I'm not understanding.
You took out the bolt with the blue arrow or red?
Old Aug 12, 2011 | 01:17 PM
the blue...the bronze circle plate would get hung up on the floor board so i took the four bolts out and pulled out the shifter then the bronze plate...then it cleared.
Old Aug 12, 2011 | 02:27 PM
You should have just took out the bolts with the red arrow and lifted the whole thing off. Would have made life a lot easier.
FWIW, I just sold my Pro 5.0 and got a MGW. Sooooo much better.
Old Aug 12, 2011 | 07:04 PM
from his explanation it sounds like he couldn't reach 2 of the bolts that hold it to the transmission for some reason so he took it off from there instead
Old Aug 14, 2011 | 08:37 PM
superdave1473's Avatar
is the mgw so much better than the pro 5.0?
Old Aug 15, 2011 | 12:24 AM
flintwrench69's Avatar
Thats why its better to just remove the shifter when pulling the trans.
