Help please I am lost
So I replaced my slave cylinder after some problems with the clutch pedal being harder then a rock .
I want to know how to tell if my steel braided clutch line is collapsed ?
The pedal goes all the way to the floor now without any resistants .
Any help would be apprecaited ..
Um I am sure I did , because I opened up the bleeder valve on the slave cylinder and had my brother press the pedal to the floor and fluid shot out ! There was no air left . I close the valve and kept trying to build up pressure in the pedal but nothing .
I even took the slave cylinder off the trans and pushed in the rod , then had him push the pedal to see if it would push my hand away . Did nothing .
So no pressure is building up !
