Trans guys head in...
Do you want to save money on the disc and potentially pull the trans. again?
Or do you want to machine the flywheel and PP (or replace) and replace (or have re-lined) the disc and know it'll be a while before you have to pull it again?
Those are your 2 options. If it's heavily soaked, you're not going to save money or time trying to run it again. If it only got a tiny bit on it, you might get lucky.
Good luck.
tranny tail down
RTV ultra black
trans. assembly lube on the outside of the bearing races holds those in place
the shift rails may need pushed around a bit with a thin piece of metal to line up w/ the bushings in the front plate
