Update on bleeding situation
I'm still having a hard time getting my clutch pedal to do anything. I've been bleeding for days and I finally started using a mityvac. I tried using it in the reservoir hole and I would constantly get bubbles. Of course I thought I had a loose connection somewhere that was pulling air (on the pump setup) but that is not the case. I also thought maybe there could be a loose connection rom the reservoir to the master cylinder, but if that was the case, I would get a drip, even just a single drop, at some point, so that's not the case.
So, if I hook the mityvac to the reservoir hole, and pump it up (I don't have a vacuum gauge on my model, so I just pumped it about 10 -15 times), I see pretty large bubbles coming out, and they eventually slow to just one bubble every 2-3 seconds, but they keep coming indefinitely. Does this sound correct?
Everyone does a great job of doing write ups, but I never see anyone mention just how long it usually takes. Any advice?
So then, I tried using the mityvac on the Tick Speedbleeder end. I used the attachment that you would use for brake bleeder screws, pumped it up, and started slowly pumping the clutch pedal. I didn't get many air bubbles, all just verrrrry tiny pin head sized ones, but I did get four cups (the mityvac cups) of fluid out (while constantly refilling the clutch fluid reservoir) and this fluid was BLACK. I mean, not even cloudy grey or a little dirty, straight black. I bled an entire quart through the system and I kept getting this fluid out.
So, my question is, how long should it take to not see any air bubbles from the reservoir using the mityvac. Also, despite not seeing many air bubbles from the slave bleeder, can this black fluid cause me to not have any pedal? (Clutch will not disengage at all). Also, can this fluid have caused my master (a tick adjustable) to go bad? How can I tell if it is bad?
Thanks for all of your help folks, as always, I appreciate it greatly.
Brian
Brian
Hey all, let me ask your opinion.
I'm using the mityvac in the reservoir hole and I pump it about 10 times (not sure what that vacuum is, could someone translate how many pumps gets you to what vaccum?) and see a bunch of 1/8-1/4" diameter bubbles come out. After a few minutes the bubbles slow to one per minute and I then slowly pump the clutch pedal 1-3 times and more bubbles come out, then slow to a trickle. I then pump the clutch 1-3 more times and more bubbles come out. I've continued this cycle for about 10 times so far and when I release the vacuum and reinstall the bladder and cap on the reservoir I still have a very spongy pedal (enough that I can not disengage the clutch at all whatsoever).
I'm more than willing to do this bleeding method for hours if need be, but does it sound normal that there is THAT much air in the system? I did NOT fill the slave prior to installing, and I installed a speedbleeder which adds a 40" line to the system. SO, I know there will be a lot of air, and it's probably compressed in there, but I have no idea how much is there. The pedal is soft, but not "right to the floor" soft, there is still SOME tension.
Anyone at all? I'll be okay with any advice at all. Thank you all very much.
be very careful you dont bleed the master dry otherwise you will be bleeding for days
Will the mityvac method work...eventually? I have no problem doing this for hours (this is a lot easier than taking the master out of the car, heh).
Thanks for all the help folks.
QUOTE]
I have extra slave cylinder laying around that I take apart so that I can use the female end of the quick connect fitting. I take that piece and add a clear hose to it. Now I setup the master the bench and clamp it down, then support the reservoir in the air with wire (or however you like), now I take the female connector and connect it together and loop the clear hose in the air (just like the reservoir) and dumping the end in the reservoir. Your simply looping the hydraulic system with a opening to let out air. Secure all the hoses. Now slowly pump the master while making sure not to run the reservoir dry and watch for bubbles. They will come out like crazy then slowly start to fad out. If you look closely you will see very tiny bubbles for awhile. Those will go away as long as you dont pump the rod to fast, just give them time to reach the end of the clear hose. Once your satisfied that theres no air in the lines, put the cap on your reservoir, disconnect the quick fitting and put it back on the car. Once on the car you notice a huge difference but there still might be air in the slave cylinder so you need to bleed it a couple of times and then you should be go to go. Hope this helps
