hydraulic clutch line
![Angry](https://ls1tech.com/forums/images/icons/icon8.gif)
From begining to end. I installed a moster stage iii with light weight flywheel. Followed all spec accurately. During break in period, shifter began slightly grinding into gear. Problem got worse and worse till my clutch would no longer engage. Had to turn car off and start in first and go.( woke a lot of people up screaming down the road @ 5000 rpms to get home). One guy is insisting its my clutch disk. Another insisting its air in the lines. (both certified master mechanics). So i replaced my clutch master cylinder to eliminate one possiblity. Big problem i am having now is i wanted to replace the o-ring on the hydraulic line into the slave too. My dumbass lost the o-ring. So my main issue is really, what size is the o-ring and is it a special kind of o-ring? Any help or advice would be greatly appreciated.
2000 WS6 Red-m6
Ls6 intake
slp intake
borla exhuast
hp tuned
nitto s\s tires
2000 WS6 Red-m6
Ls6 intake
slp intake
borla exhuast
hp tuned
nitto s\s tires
You could go to a bearing wholesaler and buy an "o-ring kit" that will have multiple sizes? I cant say for certain but as long as the old one was rubber it should work.
Ethylene-Propylene- Also known as EP,EPDM,Nordel. This is used in many applications involving nonpetroleum fluids.
It has excellent ozone& steam resistance and is used with brake fluids and nonflammable "safety" hydraulic fluids up thru 300°F (400°F in steam). Steam sterilizers are a popular application. Hardness range of 50 thru 80A
