Is this normal?
Competition Clutch Stage 2 (2250)
-clutch
-pressure plate
-throwout bearing
-pilot bushing
Resurfaced stock flywheel
ARP Flywheel bolts
Flushed transmission fluid
I was very particular when tightening down the flywheel and pressure plate bolts, making sure they were done sequentially. I also used a T56 input shaft as the clutch alignment tool. Anyways, when I take off in first gear, the car kind of jerks,shakes,shudders,chatters violently. It doesn't do it as bad at higher RPMs or when the engine is warm. I have put less than 50 miles on this clutch so far and wanted to find out if this is normal clutch chatter or if something was done wrong?
Lastly, there is a tiny bit of slack in the clutch pedal. It's not much, but with what is present, the clutch pedal seems to vibrate or bounce back and forth. I was wondering if this is just because the throwout bearing is new or if it needs to be bled? Maybe neither?
If the description isn't enough, I'll try and post a video.
Thanks
Ceramic material in discs will grip better at higher temps and engagement is more abrupt. It should get better as you drive, there usually is a break in period.
It should go away after the 500 mi break-in and your driving habits adjust to it.
I think you'll be fine.
Just for *****, did you make sure when you finished torquing down the pressure plate that it was sitting flat against the flywheel? One of the guys in the LT1 section just had this problem, the plate was sitting unevenly and was causing a ton of vibrations. You sound like you were pretty meticulous about your install, but I thought I'd ask anyways just in case.
Oh and the clutch pedal only vibrates back and forth within the amount of slack it has. If I lightly rest my foot on the pedal it doesn't do it. I'm assuming this is because theres a gap in between the clutch fork and slave cylinder, allowing the fork to bounce back and forth? I'm going to bleed to clutch soon and see if that resolves this issue.
just a learning curve AND break-in
with this said the more aggressive disc material will always be less forgiving on engagement but you should get the hang of it quickly. stop & go traffic, starting from a incline will be the most challengeing conditions.
Couldn't hurt to bleed the hydraulics I guess, but I don't think it will make anything better, unless the clutch is engaging too close to the floor.
I guess I'd have to actually drive your car to see exactly what you mean. But like I said, I think you did everything right and you just need to put some miles on the car, let the clutch break-in and let yourself get used to it and all will be well.
