Shifter rattling
Old Sep 20, 2011 | 04:47 PM
MEGATRONSS's Avatar
Default Shifter rattling
Hey guys I'm getting some good rattle in my shifter when on the gas.
I put in prothane motor mounts when the headers got installed.
Any ideas on why I'm getting so much rattle? It gets louder and louder as RPM's increase. 2002 SS with 70k
Old Sep 20, 2011 | 10:55 PM
Alex2210's Avatar
did you recently replace the drive shafts?? since you just changed the motor mounts have you check your transmission mount?
Old Sep 20, 2011 | 11:46 PM
MEGATRONSS's Avatar
No I haven't replaced the driveshaft....would changing the motor mounts put more stress on the tranny mounts or change the angle of them or something?
Old Sep 21, 2011 | 03:16 AM
Alex2210's Avatar
the angle would change, kind of like when all four your tires are deflated and you only fill the front tires up.
Old Sep 21, 2011 | 07:03 AM
djfury05's Avatar
Do you have an aftermarket shift ****? I have the white Hurst 6 speed ball **** and had to remove it because at high rpm without my hand on it that thing would be vibrating violently and making all sorts of racket.
Old Sep 21, 2011 | 01:56 PM
CaliboyTA's Avatar
do u have a hurst shifter, i had one in mine and it rattle like loose change, ended up replacing it with a pro 5.0 nd it went away
Old Sep 21, 2011 | 02:19 PM
silversrtman's Avatar
+1 My hurst **** rattles like a sob at high rpm unless i put my hand on it and squeeze a little...lol
Old Sep 21, 2011 | 09:51 PM
MEGATRONSS's Avatar
****, I do have a hurst shifter. It's the stock one from slp I believe, when I hold it down in gear it does help it a little.
So it's the shifter not the tranny mounts?
Old Sep 21, 2011 | 10:01 PM
bandit1transam01's Avatar
Same story, I have a hurst short throw and it has a slight rattle at about 50 mph but not anything obnoxious. Is there anything that can be done to quiet them down a little?
Old Sep 22, 2011 | 09:14 AM
z-maro's Avatar
I have the factory Hurst shifter and 1LE poly trans mount I believe. When I put my short stick in, I put thick double stick tape on both sides of the "offsetting block." This seems to have worked, as the guy who gave me the short stick warned me it may get loud/rattle at higher R's, but I noticed no difference over the factory stick. If that makes any sense?
