Stock Clutch??
Old Mar 10, 2004 | 10:14 PM
onefast99ss's Avatar
Default Stock Clutch??
How much HP is the stock clutch good up 2? I have a 99 Z28 M6. Help me out
Thanx Steve
Old Mar 12, 2004 | 01:26 AM
01_SuperSlow's Avatar
I don't think its good for any more than 350rwhp.
Old Mar 12, 2004 | 06:50 AM
Zero_FactiX's Avatar
Apparently it won't hold up to 315's. If I heat them up all the clutch does is spin. And i dont' have that many mods but i do have 29K on it though.
Old Mar 12, 2004 | 09:29 AM
ok thanx
Old Mar 13, 2004 | 01:30 AM
14u2nv's Avatar
Put it this way the stock 1998-2000 clutch isn't good for a stock LS1. It will be fine if all you do is use your Ls1 for groceries but if you are a very spirited driver it won't last. If you run sticky tires....drag radials and definetly slicks it WON'T LAST. Don't plan on drag racing at the track it sticky tires to much!
