Having problems installing T-56
Old Mar 11, 2004 | 02:36 PM
02Z28's Avatar
Default Having problems installing T-56
Well I got my new flywheel and clutch installed and now I am installing my tranny and I can't get it to line up right. I also installed a new slave cylinder and on the install university site when they installed their slave they left the spring out the one that is behind the throw out bearing should I take mine off? Anyone have any tips on how I can get this thing in? Thanks for your help
Old Mar 11, 2004 | 03:34 PM
Bugsquawsher's Avatar
No you need the spring on there.
Do not take it off.
It keeps the throwout bearing and Slave from just relaxin all the way back.
As far as stabbing the trannie.
1) did you use the alignment too when you installed the clutch.
2) do you have a Tranny Jack?
the tranny jack makes it much easier, you can adjust the angle.
the other thing you should check Just to make sure, is,
Does the clutch disk actually fit on the input shaft of the Tranny.
Tom
Old Mar 13, 2004 | 03:06 AM
02Z28's Avatar
Got the tranny in had to jack the back of the motor up and it went in
I don't have a tranny jack but I wish I did thanks Tom for your help and I
didn't take the spring out
