Flywheel flex??
Old Nov 13, 2011 | 01:06 AM
Dave-1970's Avatar
Default Flywheel flex??
How much if any, can a flywheel flex (on the outer most edge) when the clutch is being disengaged (clutch pedal pushed in). Especially with a heavy clamping pressure plate??? Flywheel is a monster SFI 28lb billet steel... Only mentioning manufacturer to further describe particular flywheel...Thanks
Old Nov 13, 2011 | 06:38 AM
wrd1972's Avatar
Better not flex at all cause it will negatively impact the "parallelness" of the friction surfaces. Then you will likely get slip or chatter.
Old Nov 15, 2011 | 05:21 PM
SNLPerformance's Avatar
LOL, that's a bit odd of a question but the answer is there is no "flex" in our billet steel flywheel during depression of the diaphragm spring.
Give me a call if you're having some issues and we'll answer all your questions you may have.
