Swapped out my factory Hurst w/ JSS for the B&M Ripper w/ JSS
So far so good, the B&M w/ JSS is shorter than the factory Hurst w/ JSS by far. The shifting feels slightly less notchy except for maybe going into 3rd gear.
The JSS bolted right up the the B&M with the existing B&M bolts (The JSS bolts are threaded for the factory unit, and don't fit the B&M thread pattern). The only thing I don't like is with the B&M/JSS combo, all shifting action seems moved to the right... 5th and 6th gear is a long reach, and reverse actually rubs against the plastic of the console. I may drop in the B&M stick tomorrow, it's obviously bent towards the driver for a reason, without that bend 5th/6th feels like they are eleventybillion miles away. If I do swap out the stick, I'm going to have to go back to my stock shifter ****, since the B&M stick isn't threaded enough to hold my Hurst pistol grip without having the grip *way* to high...
More to come...
More to come...
you know, i had the same issue with my JSS and the pro 5.0, reverse would rub on the console. I swapped the pro 5.0 shick back in, but did not like it at all (its hard to explain, but it just felt too flimsy). then i cut the pro 5.0 stick and it was better, but it still wasnt that great. i ended up putting the JSS back in and love the way it feels, I just have to be careful not to hurt the boot every time i put it in reverse
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
