Trans/Clutch problems...help
Old Dec 1, 2011 | 11:10 AM
02ls1z28's Avatar
Default Trans/Clutch problems...help
Long story short, never had problems in the past. Leave work the other night, everything normal. Stop to drop my buddy off at his truck, when I pull out to leave and go to hit second it doesnt want to go. I thought maybe it was just me but then when I tried to hit third it didnt want to go either. I knew then something was up. I didnt have far to go so I just got it into 5th and left it there all the way home. It sat over night and yesterday I went out to take it up the road and see if it was still acting weird. I start the car, it wont go in gear (any gear). With the clutch pushed in, when I try to put it in gear I hear a rubbing noise from under the car. Sounds like a metal on metal rub. Only does it if I apply pressure to the shifter to try and get it in gear like the clutch isnt engaged all the way or something. Any ideas?
Old Dec 1, 2011 | 12:03 PM
stephen4036's Avatar
probably the slave going out, happened to me and i had to start the car in gear.. do u have a clutch pedal? or is it no pressure?
Old Dec 1, 2011 | 01:02 PM
02ls1z28's Avatar
Pedal seemed normal, can't tell any difference
