6.0 t56?
Old Dec 6, 2011 | 01:13 PM
1997transamman's Avatar
Default 6.0 t56?
hey guys just had a question. i have been spending alot on my car in the past week or so. got vfn ws6 hood, TTm wheels with hoosier rear tires 325/35s , and a complete 6.0........ the question is im needing to rebuild my trans and i was wondering if the t56 out of my car (1998 trans am) will bolt up to that 6.0 with no problem. i figure since i have the trans out anyway i might as well pull the tired old engine and throw a cam in the 6.0 and tosh it in. can i do it pretty simple or will it not bolt up?
Old Dec 6, 2011 | 02:41 PM
genesisjoelton's Avatar
it will bolt up perfect for fact
Old Dec 6, 2011 | 10:30 PM
thank you very much sir! im glad bc i think my 5.7 just took a dump. idk what happened but it set over night in the garage from being drove yesturday and overnight antifreeze came out the top of the over flow tank and there was metalic in the antifreeze?
Old Dec 7, 2011 | 04:09 AM
bww3588's Avatar
Not necessarly. Depending on what year 6.0 you have. Lq series I'm guessing. Earlier 6.0's in trucks had a longer crank to mate up to the 4l80. Later models went to the short crank with a spacer. If you have the long crank, it will not work without modifying the input shaft.
Old Dec 7, 2011 | 09:19 AM
well i have had the the fun with a lq4 out of a 01chevy 2500hd and a 6.0 out of a 2006 yukon and never had a problem so idk what your talking about exlpain urself
Old Dec 7, 2011 | 09:38 AM
bww3588's Avatar
i just did...since you delt with an 01 and an 06, you would have never ran across this problem as all long cranks were discontinued by the time your engines were built.
99 and early 00's had longer cranks to mate to the old (TH350, TH400, 4L80, NV4500...etc)
simply because the LO4 only had the NV4500 or the 4L80E. both which were behind TBI engines (GEN I) in mid to late 00, GM decided insted of casting and supplying 2 different cranks, (long for 6.0 engines mated to 4L80's and NV4500's, and short for 4L60's and T56's in LS1 cars and 4.8/5.3 trucks) they just made one short crank and started using a spacer between the crank and flexplate/flywheel for the older transmissions.
so my point was, IF he has an early (99-early 00) engine with the LONG crank, it will not bolt to the LS1 T56 without modifying the input shaft.
Old Dec 7, 2011 | 09:41 AM
bww3588's Avatar
an LT1 T56 will bolt to the long crank 6.0 no problem. just requires a certian flywheel with certian holes...etc.
Old Dec 13, 2011 | 07:36 PM
TDP's Avatar
TDP
I haven't tried it in this particular application, but I don't see why the C6 Vette pilot bearing wouldn't make it work. Seeing as how it sits in the big bore at the very end of the crankshaft.
Old Dec 13, 2011 | 07:55 PM
bww3588's Avatar
It has nothing to do with the pilot bearing.
Old Dec 13, 2011 | 08:00 PM
TDP's Avatar
TDP
The pilot bearing depth actually has a lot to do with the mounting of the clutch/flywheel/transmission. In 2005 GM went to a different bearing which fits in the large bore at the back of the crank.
You missed the point. With the new style pilot, it will allow for a shorter input shaft, *or* a shorter depth. Like I said, I haven't tried it so I don't know for sure. Just as idea to kick around..
Old Dec 13, 2011 | 08:23 PM
bww3588's Avatar
Ok. Your missing the point also. The ls1 has a longer input shaft than the gen I transmissions, hence the reason for a crank spacer or longer crank to mate up to the 4l80.
Installing a pilot in the rear most bore of the crank will only further amplify the problem.
Old Dec 20, 2011 | 11:51 AM
Turtle Bite's Avatar
This I am curious about. I have an 03 lq4 and 2000 lq4 with the long crank. I was trying to figure out why I couldnt use the LT1 setup with the long crank 6.0. Since my setup is going into an early Nova, the style of clutch hydraulics I use is not that important.
Would you use an LT1 flywheel or an LS1? If you use and LT1, would you still use the LS1 starter? I already know that the LQ4 has 11mm bolts and the LT1 uses 7/16 bolts. From what I understand the LT1 also uses a 153T flywheel while all the late model LS flywheels and flexplates are 168T.
Old Aug 10, 2015 | 08:55 AM
01SSBIGDADDY's Avatar
Default 6.0 t56
Ok so I was unaware of the long crank on the 00 lq4. I've already spent a fortune on maching, decking, heads, cam etc. I already have engine together ready to go in and now I realize my t56 ls will not bolt up. So from wat I've read I can change cranks or change my input shaft to a lt1 input shaft. Is this correct. If so which is recommended. Also I have an old school buddy who said he use to cut input shafts down to work. If so is that an option and wat r the risks Thanksc
Old Aug 11, 2015 | 12:42 PM
jmd's Avatar
jmd
The pilot depth is easy and the spline engagement is easy enough to verify.
However, I've never heard of a flywheel to do what you're proposing.
So crank swap it is.
Old Jul 13, 2017 | 07:39 AM
hatchedb18c's Avatar
So a lt t56 will bolt up to a Silverado 2500 6.0 4l80 trans correct is that what I'm understanding
Old Jul 13, 2017 | 08:52 AM
bww3588's Avatar
if it has the long crank. If it has the short crank, you will need the spacer, bolts and certain flywheel.
Old Jul 13, 2017 | 09:10 AM
How do I tell if it's the long crank?
If it is long crank it will bolt right up? What flywheel and clutch do I use?
If it has short crank I would be better of going LS t56 correct
Old Jul 13, 2017 | 08:42 PM
jmd's Avatar
jmd
If you can shorten the crank 0.400" and still have seal to crank contact, it's the long one.
You have it backwards.
All LS1 / LS6 are short crank. A short crank truck engine can use whatever bolts up to an LS1.
The trucks some years had long cranks. No flywheels made for these.
Old Jul 21, 2017 | 09:15 PM
pressureprows6's Avatar
As long as you dont have that queer 99-00 long crank its a bolt in and go......i have a 04 6.0 in my 02...bolt in....
