T56 stuck in fourth
Old Dec 18, 2011 | 08:52 PM
chevy2fast's Avatar
Default T56 stuck in fourth
Just put a new monster stage 2 clutch in today everything went fine so took it down the road to make sure everything was ok and then I couldn't shift out of forth gear? Drove it real light 0 torture smooth engagements clutch still functions corectly just stuck > anybody have any ideas?
Old Dec 18, 2011 | 09:01 PM
SWEET98SS's Avatar
Will it come out of gear in with the car off? Might not be releasing all the way, what master do you have?
Old Dec 18, 2011 | 09:02 PM
thesource's Avatar
Common issue with the T56 if they have stock shift keys or the shimming is a little too loose.
Old Dec 18, 2011 | 09:09 PM
chevy2fast's Avatar
No it will not come out even with car off won't even float out of gear with 0% stress from enine and stock master.
Old Dec 18, 2011 | 09:11 PM
VandykeT/A's Avatar
Get ready for a rebuild or learn to avoid 4th. Both of mine got rebuilt over the exact same thing. Let the car sit a day or so and it'll probably pop back out. You can try playing with it and it might come out. Tick rebuilt both of mine and Ive had great service from them. I'm about to buy another car tomorrow so they may be getting to do a 3rd one for me. Good Luck.
Old Dec 18, 2011 | 09:30 PM
SWEET98SS's Avatar
My last car did the same thing, got stuck in gear, ending up getting a new tranny.
Old Dec 18, 2011 | 09:39 PM
chevy2fast's Avatar
Any possibility of being able to pull the shifter and manually unjamming throughout the forks
Old Dec 19, 2011 | 07:09 PM
chevy2fast's Avatar
Hell got it fixed, the shift keys must have just been catywhompus
Old Dec 23, 2011 | 12:27 PM
TDP's Avatar
TDP
It's usually not a shift fork issue. What most likely happened is the 3-4 keys were in the process of breaking. Once they get beat up, they'll come out of place putting the 3-4 sleeve in a bind, hence causing it to get stuck (in gear). If you managed to get it "un-stuck", then you probably just finished breaking the keys so and the pieces fell out, allowing the sleeve to move freely. So it's definitely not "fixed", you'll need a rebuild before it ruins the engagement teeth on 3rd and/or 4th gear, if it hasn't already. If you are not going to DIY, check my sig for upgraded T56 builds, starting at $680 parts/labor and cheap shipping if needed.
Thanks
Old Dec 23, 2011 | 03:44 PM
karpetcm's Avatar
Mine did that and that was the end of the tranny. I couldnt even kick it out of fourth, lol. Had to drive home from an hour away on top of it in traffic which meant the clutch was toast.
Old Apr 4, 2020 | 05:46 PM
Chris Butler's Avatar
Thanks
What is your info for your business? I would like to check out your prices
Old Apr 4, 2020 | 10:34 PM
PM sent...
