Stupid Question on Trans Install
I put a new pilot in (tapered side towards the motor, which is apparently the wrong way, but it looks like it doesnt matter) and dont want to mess it up trying to get the input shaft in.
Is there any tips or tricks to getting it back in? Or do I need to pull everything back off and put a new pilot in the right way? It should be easier with the motor out of the car and not on a lift like most do so I didnt expect this to be the one thing so far to give me problems.
Any help or ideas appreciated? Thanks
You may need to loosen the pressure plate bolts for things to align. You you want them loose enough that the disc hub can move around with the tool inserted.
When the tool is in the disc hub spline and the pilot, wiggle it fully up and down.
Stop it about 1/2 to 5/8 upwards and tighten the pressure plate bolts. The tool should at this point slip pretty easily in and out just like you want the input to be able to do.
