Ls7 swap need answers
Switching stock T56 clutch to LS7 was wondering if I can still use the same slave cylinder and throw out bearing. I did just replace it a few months ago? Any answers would help thanks
If the systems bled properly using a mighty vac or the old fashioned way, then it should work perfect. Replace the pilot bearing as well while your in there, its a 10 dollar gm part
