T56 Wont go into reverse
hey i have a 95 camaro lt1 6 speed with the T56. I removed the reverse lockout solenoid cleaned it and lubed it works great. Car will go into reverse gear when car is OFF if the car is running it will go into the gate past the reverse lockout part and the reverse lights will come on sometimes i can get it in, other times it just grinds. Car idles at 1000-1100 rpm this could also be the problem. Im going to re bleed the clutch what do you think?
