clutch quick disconnect?
Have you got the Part Number for this adaptor fitting?
I live in the UK and am currently building an AC Cobra replica with LS6 + T56
I'm currently stuck! I've been trying to source the hydraulic line with no look without buying it complete with master cylinder which I don't really want to do as my Cobra kit pedal box comes complete with a master cylinder - I was going to modify and loose the quick-disconnect end by welding on a fitting but would prefer to use the Mcloed adaptor.
I've sent various emails to Mcloed with no reply - When call Mcloed they say I need to speak to their tech support to get the part number - but when I call the tech support line it's constantly engaged.
Does anyone have the Mcloed Part Number for this fitting or an alternative supplier.
Someone should start selling this on Ebay
Thanks in advance
Where did you get your engine from? The box should've come with the hose - mine did...
Robin
Robin
Thanks for the links but I managed to get through to Mcloed yesterday and ordered a couple of adaptor fittings $33 each
I got my engine from a company called Regal Performance - excellent to deal with they supplied the full package crate LS6 + T56, reprogrammed computer and modified harness - modified low slung generator in-fact pretty much everything I need to get up and running a part from the quick - disconnect clutch line
Thanks Dave
