tick master install
I dont know how people do this install without removing the brake master! I must have just had the angle all jacked up I know its a tight fit but damn!!
just a tip if your having the same problem i was...take the time to loosen those four bolts you dont even have to remove the clip on the brake pedal, just need a little extra room to slide that bad boy in much easier.
I hope this saves someone the 5 hours i wasted fighting it!!
enough complaining though, the tick looks great and once i finish getting the clutch swapped out im sure it will be a great product!
Im sure its one of those things that once you get the angle right it slides right in but it just wasnt happening for us!!
