SPEC 3 or 3I
Old Mar 18, 2004 | 07:11 PM
me_eat_rice's Avatar
Question SPEC 3 or 3I
i am interested in either of these clutches. I will soon have a 9 inch rear end and 3.5 inch driveshaft. I plan on going to the trackabout 6 times this summer. Should I get the 3 or the 3I?. Also what else will I need to order with it?
Old Mar 19, 2004 | 11:39 AM
SilverGhost's Avatar
Motorboater
I have the 3I and am digging it alot so far. I'd recommend it, not too much more money for the extra power it holds..VERY streetable clutch,too.
I also got the billet flywheel with it. I'd recommend that also, very nice piece.
Seeing as you have a 99 you will want to order the upgraded hydraulics as well, you won't need a adjustable master with this clutch which is nice and saves money but you will want the upgraded hydraulics.
Old Mar 19, 2004 | 12:19 PM
NBM~01~WS6's Avatar
I just put on my procharger and i'm getting my spec 3 clutch installed in a few weeks...I went ahead and order the spec 3 xpad cause that will be enough to handle what i have....I went ahead and order the spec billet steel flywheel also...
Old Mar 20, 2004 | 01:35 PM
so is there anything else to get. I think I've head of getting newer master & slave.
Old Mar 20, 2004 | 08:27 PM
SMOKIN01TA's Avatar
yep, get some better 60' times. you should be able to go 1.8s on nittos. you will like you times much better then.
Old Mar 22, 2004 | 07:19 PM
dont i need new master?
Old Mar 22, 2004 | 07:31 PM
SMOKIN01TA's Avatar
some do some dont. but its recomended. try it, if it dont feel right, change it. i would do it the first time
Old Mar 22, 2004 | 09:24 PM
Greg Fell's Avatar
I put a 3i in my zo6. It chatters less than my 3 carbon (not the x pad) did in my t/a. It is awesome, hardly any chatter (and only 400 miles). Once I get to track and do some dumps on slicks, I fully expect it to be totally quiet.
