Issues after TICK Adjustable Master
Old Feb 11, 2012 | 02:31 PM
Ilikeppie's Avatar
Default Issues after TICK Adjustable Master
So the other day I installed the Tick in the car adjusted it and bleed it all out. Took it for a spin everything was working great. Then the next time I take the car out drive it for about 20 miles and as I am pulling into the driveway the clutch pedal sticks to the floor. So I figured maybe I hit a air pocked or something. I have been trying to bleed it but nothing I do is regaining pedal pressure the slave cylinder has only about 3000 miles on it. Do I just need to keep trying to bleed it or should I be pulling the transmission and swapping the slave again?
Old Feb 12, 2012 | 11:59 AM
Ilikeppie's Avatar
Has this happened to anyone else after installing the Tick master?
Old Feb 12, 2012 | 02:23 PM
LimeyZ's Avatar
Is the fluid in the master cylinder still clear after bleeding then driving 20 miles?
What slave do you have installed? One of these?
http://www.ls1.com/forums/f65/clutch...y-pics-162985/
Were you able to set the Tick master just right without over extending the pressure plate?
Old Feb 12, 2012 | 10:26 PM
6.0 silverado's Avatar
This did not happen to me after my install.
Do you have a remote bleeder?
Old Feb 12, 2012 | 10:32 PM
Ilikeppie's Avatar
I have the one installed that is depicted far to the right in the picture of all three of them. also the fluid was still clear and a little bit low but not empty. I don't have the remote bleeder installed as I have not had the transmission out since i bought it
