Power Shifting???
Sorry for the newbie questions.
If you powershift that stock t-56, be prepared to ask santa for another one soon. I should know.........
ya, if you miss gears it makes a difference, but if you are powershifting correctly, why is it bad for the tranny?
but i still don't understand how powershifting is harder? think about it...if you are flooring your car up to ~6k rpms, letting off the gas completely, shifting, then punching in when you have it in gear, your tranny is getting a beating because of the high rpms. now when you do the same, only you never let off the gas pedal, the rpms are not increasing by much, and the tranny is still getting the high rpm wear that it would shifting normally under heavy load. how is the former better than the latter?
You will see a lot more LT1 M6 f-bodies in the 9's than the LS1 variety....the reason...they take a lot more abuse....LS1 owners simply swap out to a built auto.
Although a succesful poweshift may not "blow up" the trans or show any immediate harm, I do still believe it will effect long term durability. it is just more strain on everything. If done right though, the trans should still last a long time, just not longer then if you never powershift. Also try to change trans fluid atleast about once every year or two. I use Redline MTL. works awesome.
