Clutch Starter Switch Issues
Old Feb 18, 2012 | 03:16 PM
AnimalSS's Avatar
Default Clutch Starter Switch Issues
Been having issues the last week or so with the clutch starter switch on my SS ('00). Seems everytime I would try to start the car, nothing happened until I pressed the clutch a little harder. Get in the car this afternoon, same thing except now it won't start at all. So, I take apart the dash, remove the switch, get a new replacement from the auto store, install the new switch (drumroll please) and the car still won't start. So, what else could it be?
Old Feb 18, 2012 | 03:46 PM
therealcreeper's Avatar
are you sure it was related to the clutch switch? or could it have just been the process of turning the key a few times?
maybe vats is going?
Old Feb 18, 2012 | 04:37 PM
AnimalSS's Avatar
Don't know. Car responds as though I'm trying to start it without pressing the clutch. I've replace that starter switch as well as the starter and ignition fuses. No difference.
Old Feb 18, 2012 | 06:16 PM
TrybalRage's Avatar
Does your 'security' light come on?
Old Feb 18, 2012 | 06:37 PM
AnimalSS's Avatar
All the "system" lights come on when the key is turned, as they normally do.
Old Feb 18, 2012 | 07:06 PM
Spartan7's Avatar
Short the wires going to the switch. If it starts, there's your problem. If not, look elsewhere.
Old Feb 19, 2012 | 09:32 AM
AnimalSS's Avatar
Any other suggestions on what the issue could be?
Old Feb 20, 2012 | 12:11 AM
_JB_'s Avatar
Maybe there is something holding the switch closed? Have you tried to visually check the switch is releasing with the pedal?
Old Feb 20, 2012 | 09:29 AM
oldmano2z's Avatar
i did an a4 to 6spd changeover and just spliced those wires together deleting the switch altogether. code comes up every now and then. just have to remember to take out of gear. old timer way. can reach in and start car from outside now. just got to remember e-brake and outa gear.
