tick master, clutch travel when warm
Hello,
I have a 2000 T/A with a T56 trans, tick master, ls7 clutch, with new slave cylinder. I finally got the tick adjusted the way I wanted. The car wouldn't roll when in gear and reved up. Finally take the car for an extended drive, and when the car was at operating temp, the clutch pedal seems to come up farther off the floor? It is still below the brake pedal some, but didn't want to send too much fluid to the slave and cause an issue with that. Any help would be appreciated as I am kind of lost on what to do from here.
Thanks,
Travis
Thanks,
Travis
one thing to check, make sure that the clutch line is not resting on the exhaust. My stock clutch would randomly disengage on the highway and i found that the line was touching my cat. I zip tied it to the frame and the problem went away
Hello,
Thanks,
Travis
Thanks,
Travis
