New Spec stg 2 clutch, new slave , still not going into gear??? Help
Old 02-26-2012, 07:46 PM
BBNfan's Avatar
Default New Spec stg 2 clutch, new slave , still not going into gear??? Help
Well I replaced my clutch, slave, fluid, and the car still will not go into gear would not bleeding the slave properly cause this? I am new to these cars and didn't do my homework and get the speed bleeder so used the method I found on here using a piece of hose and a spark plug boot seemed to work I have a great pedal feel but evidently I still am not engaging the clutch help please thanks guys
Old 02-28-2012, 11:09 AM
SPEC-01's Avatar
Did you check the measurements referenced on the sheet provided with the clutch kit? if so, what were your measurements? Did you install the shim? What flywheel is being used? Let me know and I will be happy to assist you further! Thanks,
Quick Reply: New Spec stg 2 clutch, new slave , still not going into gear??? Help
