Benefits of billet flywheel vs. stock?
I'm in the process of piecing together a transmission setup, which will be centered around a new T56 Magnum. Most aftermarket places are offering billet flywheels. What is the benefit of a billet flywheel over a stock style flywheel? Jegs offers a stock style for $100 (part number 601260). What do I get if I spend 3x as much on a billet unit?
The car is going to have somewhere around 500RWHP, and I intend to run a quicktime bellhousing. and I'm planning on running a Mcleod RST clutch. I'm not against spending the money for a good flywheel, but I'm also not a fan of pissing money away for no reason. Can some experts chime in and help me understand what's inadequate about a stock style flywheel?
I can tell you one benefit, the threads for the pressure plate on the billet flywheel are far less prone to pull out than what you will see on a cast steel flywheel. I did a clutch job on a Mustang about 3 months ago and the damn pressure plate bolt threads pulled out on 2 of 6. I threw the old flywheel in the garbage and made him buy another one.
The gen4 engines have a slightly thicker crank than the gen3 motors.
I thought u may have a preffered assembly
From what I know..
They are stronger, they are less prone to warpage because of this. I wouldn't be too sure that those stock cast flywheels from jegs are zero balanced either.. meaning it may need to be balanced with your new clutch.
Also, like my chromoly lightweight flywheel, it came in a kit with my clutch which made it fairly cheap. Which is probably why you don't see a lot of people using high end clutches with stock flywheels.
You would need to talk to the clutch companies like Spec or Monster to get a better answer to your question.
uhh duh if it has billet in the name its obviously better. does there need to be any other reason? see i dont say i have a pt7675 turbo. i have a billet pt7675 turbo. See the difference? one is normal, the other just sounds sexy. i also have a billet ram flywheel with my rxt. man im flying off the cool charts!
joking aside i chose a billet flywheel because of safety reasons. its sfi certified and i like my feet. Does it mean its better or stronger?? i dunno but i just didnt trust the stock cast flywheel...
another option is a forged chrome molly fw...I got one from F1 Racing for $225. Has removeable weight for motors that are internal balance..but have it spun by a machine shop to confirm. Mine was off and needed some material removed
