6spd to th-400 speedo? urgent
Im installing a speed sensor in my th400 I need to tie into my 6spd speed sensor wires car was 2001 6spd does anyone no which plug or color wires i need to splice into?
Your T56 Speed Sensor wires are on that black connector that goes to the Speed Sensor on the Trans..crawl under there and take a look, it's pretty straight forward to see..
If you dont know that then I want to see how are you adapting an electronic Speed Sensor on the TH400?
I use the ABS Hub Sensors...fwiw.
