very odd shifter movement
2000 ws6, m6. while cruising on the highway in 5th gear, it moves back a 1/2 inch or so when i give it gas. If i let off the throttle in moves back up. Monster stage 3 clutch with billet flywheel put in a year ago. Rebuilt t56 installed 2 years ago. The T56 was installed by a local tranny shop with 35 years experience and very reputable. The clutch was installed by me in about 5-6 hours on a lift taking my time. Just started to happen today.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
remember now. it only happens in 5th. I would think if it were one of those two it would happen in all gears. Maybe a loose gear or bad syncros?
If i step on it hard the shifter moves right out of gear.
The other day I was cruising on the freeway and BANG! pops outta gear and started making a horrible growling noise. Anyways brought the car back home, Ripped the tranny out and apart, the snap ring and 5/6 synchro keys and retainer wires broken/stuck to the internal magnet and i guess a broken part of one of the keys made way into the cluster gear bearing and tore it apart. Now waiting on replacement parts from Tick.
I'd pull the tranny asap or have it looked at, Itll be cheaper to fix now then to wait like i did and destroy bearings and thrust washers. Sorry to be the bearer of bad news
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
