B&M RIPPER REVERSE PROBLEM!!!!
I recently installed a B&M Ripper shifter in my 1999 C5 corvette But Now it is hard as hell to get the thing in reverse, reverse engages fine but the problem is getting it all the way to the right to put in reverse. It is so hard to get it over to the right that i have to use two hands(almost impossible with one!!!) to get it over into reverse. i followed the intructions perfectly and i had no problem with the install at all. Please reply if you have had the same problem or if this is normal or can be fixed. Thanks!
