Can someone please explain this. Please.
Old May 1, 2012 | 03:20 PM
armyboyatc's Avatar
Default Can someone please explain this. Please.
I recently swapped a motor and trans from one car into another car. The car this setup was in was working flawlessly. Same motor, trans, clutch, flywheel. The only things I changed were the slave cyl and master cyl. Now the clutch has an extremely high engagement point. Ive blead it the old way (pumping clutch) and with a mighty vac. I can not get the engagement point to lower. The pedal is firm with virtually no play when you press on the clutch at the top. Can someone please give me some insight on why this is happening?
Old May 2, 2012 | 04:39 PM
SPEC-01's Avatar
Did you compare crank-depth and bearing/slave depth between the cars? If there was a difference in either of these it would affect the engagement point. Also, did the second car have a shim behind the slave and the original car not have this?
Old May 2, 2012 | 06:28 PM
chrysler kid's Avatar
Sounds like the new master is to blame. Try another or mod it to be an adjustable master as mentioned in another thread
Old May 2, 2012 | 07:01 PM
armyboyatc's Avatar
It's the exact same setup. I used the shim that came with yalls setup. The only things that have changed is the master and slave. Same motor,trans, clutch, etc.
