which way does the pilot bearing go?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Sorry for this stupid question but i really don't remember which way the pilot bearing goes in, I have a couple pictures. And do i just press it in flush to the step on the crank or does it sit in alittle further?
I had a bushing wear out in 8k miles. I've never had a single issue with a bearing. You'll be just fine with a bearing. Worn bushing can damage the input shaft bearing and make it tough to get 4th gear. The bearing will out live the clutch so aslong as you replace it when ever the clutch is out, you'll be fine.
